SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
Apr 22, 2019Guru - Experienced User
Is the disable radio button not working for you?
gr8sho wrote:
Hello,
Can you kindly explain please how on earth you're ablie to get the switch to enable disable auto updates?
SW_ wrote:
gr8sho
Apr 22, 2019Virtuoso
I don't have it. Was it introduced in .48? This is a question I've asked before with no response. I don't want to update unless I know for a fact it comes with the new firmware as I'll have to schedule a factory reset.
- FURRYe38Apr 22, 2019Guru - Experienced User
Oh ok. Well seems to have been intro'd with v48 as it was posted by SW. I'll be updating the RBR I have to check this as well.
- gr8shoApr 22, 2019VirtuosoOkay, thanks. The reason I would want to do factory reset is I had telnet'd into both boxes to turn off auto updating. If I have access to a switch, I'd rather put the devices back into their natural state.
Also if .48 in fact introduced the switch, I'd want to send a shout out to Netgear for listening to our requests as this would be be very much welcomed.- Dfran1Apr 22, 2019Apprentice
maybe that is why my orbi took auto update, I only telneted into one, not the satelite
are these the commands to use on both?
nvram set orbi_auto_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_check_for_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_update=0 <ENTER> (no spaces after set)
I just factory reset on 48 and configured from scratch
I don’t have that page at all,unless ro get it to show by a telnet or??
It’s not there
Also satellite even after factory reset sucks!! Connected devices to the satellite get 1/2 the speed vs connected to router, WiFi is weaker also
so factory reset has done nothing.
‘I need 210 back on and to stay on permanently, the telnet method don’t work either, tried it twice, how do I tell netgear to get the hell out of my purchased equipmen and get me to lock this at 210 that I have great results with.
thank you
- gr8shoApr 22, 2019VirtuosoThe page will be under Advanced tab using the management console via web under Administration --> Firmware Update
Its not there
2 different computers and web browsers
the only thing I can think of is Netgear is releasing diferent versions of firmware at diferent times, example : they released the one with that option and maybe other things then during the day or next day they changed it and deleted it for any one else.
