SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
Apr 22, 2019Guru - Experienced User
Oh ok. Well seems to have been intro'd with v48 as it was posted by SW. I'll be updating the RBR I have to check this as well.
gr8sho
Apr 22, 2019Virtuoso
Okay, thanks. The reason I would want to do factory reset is I had telnet'd into both boxes to turn off auto updating. If I have access to a switch, I'd rather put the devices back into their natural state.
Also if .48 in fact introduced the switch, I'd want to send a shout out to Netgear for listening to our requests as this would be be very much welcomed.
- Dfran1Apr 22, 2019Apprentice
maybe that is why my orbi took auto update, I only telneted into one, not the satelite
are these the commands to use on both?
nvram set orbi_auto_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_check_for_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_update=0 <ENTER> (no spaces after set)
Also if .48 in fact introduced the switch, I'd want to send a shout out to Netgear for listening to our requests as this would be be very much welcomed. - FURRYe38Apr 22, 2019Guru - Experienced User
gr8sho Well, I think you can hold off. I DON"T see any disable radio buttons of Auto update after manually loading v48 and doing a factory reset on the system and setting up from scratch. Nothing that has a enable or disable Auto update. I check two different browsers to be sure.
Interesting to know were SW_ got this from....
After setting up, both RBR and RBS are working fine for me. Speeds are to spec for 200/10 wired and wireless. Daisy Chain and Fast Roaming disabled. Beamforming and MIMO enabled...
Also if .48 in fact introduced the switch, I'd want to send a shout out to Netgear for listening to our requests as this would be be very much welcomed.- gr8shoApr 22, 2019Virtuoso
Agreed. The fix given is certainly not worthy of my time given the description. And I was so looking forrward to gaining that elusive control...
Well, if this is the case then it may not be forth coming. Users been asking for this for a long time. I presume if NG hasn't made it an official feature by now, might not do it at all. Who knows. :smileyfrustrated:
