SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
gr8sho
Apr 22, 2019Virtuoso
I don't have it. Was it introduced in .48? This is a question I've asked before with no response. I don't want to update unless I know for a fact it comes with the new firmware as I'll have to schedule a factory reset.
Dfran1
Apr 22, 2019Apprentice
I just factory reset on 48 and configured from scratch
I don’t have that page at all,unless ro get it to show by a telnet or??
It’s not there
Also satellite even after factory reset sucks!! Connected devices to the satellite get 1/2 the speed vs connected to router, WiFi is weaker also
so factory reset has done nothing.
‘I need 210 back on and to stay on permanently, the telnet method don’t work either, tried it twice, how do I tell netgear to get the hell out of my purchased equipmen and get me to lock this at 210 that I have great results with.
thank you
- gr8shoApr 22, 2019VirtuosoThe page will be under Advanced tab using the management console via web under Administration --> Firmware Update
- Dfran1Apr 22, 2019Apprentice
Its not there
2 different computers and web browsers
the only thing I can think of is Netgear is releasing diferent versions of firmware at diferent times, example : they released the one with that option and maybe other things then during the day or next day they changed it and deleted it for any one else.
gr8sho wrote:
The page will be under Advanced tab using the management console via web under Administration --> Firmware Update - jweiseApr 22, 2019Apprentice
There is no switch to stop auto update on the firmware update page, on my version of 48!!!
