SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
gr8sho
Apr 22, 2019Virtuoso
Okay, thanks. The reason I would want to do factory reset is I had telnet'd into both boxes to turn off auto updating. If I have access to a switch, I'd rather put the devices back into their natural state.
Also if .48 in fact introduced the switch, I'd want to send a shout out to Netgear for listening to our requests as this would be be very much welcomed.
Dfran1
Apr 22, 2019Apprentice
maybe that is why my orbi took auto update, I only telneted into one, not the satelite
are these the commands to use on both?
nvram set orbi_auto_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_check_for_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_update=0 <ENTER> (no spaces after set)
