SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
Dfran1
Apr 24, 2019Apprentice
Well all the firmware after 210 for me is just not good.
My IFTTT app works great with210 and all others is intermittent.
WiFi is hit and miss with all newer firmware in distance and hiccups. I see this with my far cameras live playing.
Backhaul is hit and miss with all newer firmware in speed and hiccups.
I tried factory reset on both router and satellite on 48, took a day to settle in and still hiccups in WiFi.
All the same settings (set manually), nothing complex.
I am running 210 now again, I did the auto update telnet on both this time. Hopefully that stays
I certainly see that 210 had problems also for others, none of this stuff makes sense unless components are off tolerance and causing hiccups, for some on some firmware and not others, I can state that this stuff also applies to other routers manufacturers Ihave had, just one of those things, it is what it is.
