SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
DorkiOrbiFW
Apr 30, 2019Apprentice
FURRYe38 wrote:
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
rRamjet wrote:
I just updated and everything seems to have gone well. I was prevously experiencing timeouts (hangs) every few days. All devices appeared to still be connected but the internet did not respond.
In reading this thread I notice a web GUI. I thought you could only manage Orbi via the mobile app. How do I find the URL for the web GUI.
TIA
FURRYe38 , I get what you are trying to say, but I highly think that rRamjet knows and has the Orbi in Access Point mode already. The suggestion that I gave rRamjet should be the solution and it is in his best interest to look and/or ask questions in regards to his issue at this discussion: https://community.netgear.com/t5/Orbi/Unable-to-login-to-ORBI-as-Access-Point/td-p/1181535.
Best,
Apr 30, 2019Guru - Experienced User
I know, just making sure he has all the info he needs...
Best,
- rRamjetApr 30, 2019Aspirant
Thanks everyone.
I found I was connected to the modem (Telstra Max WiFi) was why I could not login via orblogin. I did turn the Telstra WiFi off but it appears it turned itself back on in the past couple of weeks. This might be from an auto firmware update as I cant think how else it could have re enabled.
Today I also just followed the Netgear video to put Orbi into AP mode vs Modem mode. Not sure what this does but following your instructions I did it anyway. I can confirm I can login to Orbi from App and Browser and can login to Modem via the Testra Gateway browser login URL. All looks good.
Now I just need to see if the internet pauses I have been getting go away.
Thanks all
- DorkiOrbiFWApr 30, 2019Apprentice
rRamjet wrote:
Thanks everyone.
Thanks all
rRamjet, I am glad you resolved your issue! Hope you are enjoying the Orbi and reach out to me anytime or FURRYe38 in a future disucssion if you have any questions (we're pretty knowledgeable in diagnosing the system :smileyhappy:) about something that hasn't already been addressed.
Best, - FURRYe38May 01, 2019Guru - Experienced User
Be sure to do a config backup to file for safe keeping. Saves time should you need to factory reset the system on this version of FW.
Enjoy. :smileywink:
rRamjet wrote:
Thanks everyone.
Thanks all
- gr8shoMay 01, 2019Virtuoso
I get squeamish when I read things like this. First off, the choices in the Orbi management console should be AP or Router mode, not modem. Unless you're using a modem/router combo Orbi. AP stands for access point. Basically think of your Orbi as an expensive extender when run this way. The Telstra box ends up doing all the primary router functions including DHCP server address assignments.
If your ISP box can be set to bridge, DMZ or passthrough mode for the Orbi, it would be possible to run the Orbi in its natural riouter mode.
In either of these modes, you are correct to disable WiFi on the Telstra box. A firmware update should not change the settings on your modem or gateway box unless they forced it to perform a factory reset which would be highly unusual. Most people would scream bloody murder if it happened behind the scenes.
