SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
rRamjet
May 06, 2019Aspirant
So this was all going well then I decided to try this bridge mode thing... (there goes 2hrs of my life).
I researched a few articles and watched a video to prepare for this change.
Put the Telstra TG799vac into bridge mode per the GUI.
Put the Orbi back into Router mode from AP mode (found out that when in AP mode you loose Cricle and Armour etc.).
The TG799 appeared to line sync with my ISP (Aussie Broadband) OK according to the lights on the box itself.
I could get to the Orbi GUI OK but it just kept saying no internet connection. When I would troubleshoot it, it would ask for PPPoE user and password despite me selecting in the Orbi settings that this was not required.
I could not get back to the TG799 as it was now off the grid in bridge mode even when I turned the WiFi back on. Did a few restarts, called ABB and they could not help so stuck the pin in the back and reset it.
I am now back to the TG799 in default mode which I presume is a router/modem mode (turned off the WiFi) and Orbi in Router mode. What is the downside of doing it this way (both in Router mode) vs bridge mode which did not work out for me? Is there a downside?
Should I have changed the hardware setup at all? I have a network cord running from the TG799 LAN port to the Orbi Internet Port (Yellow). I also tried from the WAN port (Red) on the TG799 but that did not seem to change anything.
Should I have changed other settings on the TG799 other than just slecting bridge mode.
Thanks
May 06, 2019Guru - Experienced User
Did you power OFF both modem and Orbi for 30 seconds, then power on the modem and let it sync then power on the Orbi and check for internet status?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try Option #2 if you want to use the Orbi in router mode with the modem in router mode.
Thanks
