TommyWeir
Jul 22, 2019Aspirant
New Orbi RBR53 - a few issues
Hi all I set up a new Orbi router plus two satellites off my modem. WiFi turned off on modem and getting steady speeds on the Orbi network. Two issues have emerged. 1. I can't downl...
- Jul 22, 2019
Hi TommyWeir, welcome to the community. Another user in the community describes a similar scenario and was able to get around it by the following steps.
1. Go to Safari on Apple iPad (probably works on Android with other browsers too)
2. Type in "orbilogin.net" (not including inverted commas)
3. When prompted type in username and password which should be "admin" and whatever your password is printed on the plastic slip cover of your router with the QR code, unless of course you've created a new one on initial setup.
4. Having loaded you into orbilogin.net you should then minimise Safari and attempt downloads, updates and access to previously inaccessible trusted sites.
Keep us posted.
Dexter
DexterJB
Jul 22, 2019NETGEAR Moderator
Keep us posted.
Dexter
TommyWeir
Folks, many thanks for the swift and helpful reply. All sorted, the AP mode did the trick.
