wyncdavies's avatar
Jan 08, 2021
New Orbi RBS50 and RBS40v firmware won't install properly
There are new updates for both the RBS50 and RBS40v available but I can't get either of them to update either automatically or manually.  When I attempt to update them manually I get two different er...
  • wyncdavies's avatar
    wyncdavies
    Jan 08, 2021
    I was able to log in to each of the satellites using the IP address and do the updates manually from there.  I didn't even know you could log in to each one individually.  Thanks for pointing that out.  Everything is supposedly up-to-date now...
