BarryMan
Jun 29, 2020Aspirant
New Orbi router causing broken internet links
I installed the RB50 and satelite. I basically unplugged the old apple wifi router and plugged in the Orbi. Did all the set up. Wifi is working. Orbi is plugged into a router and that router is ...
Jun 29, 2020Guru - Experienced User
What is the Mfr and model# of the router the Orbi RBR is connected too?
Is the Orbi system operating in Router or AP mode?
- BarryManJun 29, 2020Aspirant
What Firmware version is currently loaded? on the Orbi RBR50 it is V2.5.1.16
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? the dsl modem is the Smart/RG VDSL2 Modem.What is the Mfr and model# of the router the Orbi RBR is connected too? the router is the 844E GigaCenter
Is the Orbi system operating in Router or AP mode? Not sure where I can check this
thanks
- FURRYe38Jun 29, 2020Guru - Experienced User
So you have a router already at the GigaCenter which is also a modem. This is connected to a VDSL modem as well?
The orbi already is a router and having two routers on the same line will cause problems.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying option #3 with the Orbi RBR.
- BarryManJun 29, 2020AspirantThanks! I will give it a try
