BarryMan
Jun 29, 2020Aspirant
New Orbi router causing broken internet links
I installed the RB50 and satelite. I basically unplugged the old apple wifi router and plugged in the Orbi. Did all the set up. Wifi is working. Orbi is plugged into a router and that router is ...
Jun 29, 2020Guru - Experienced User
What is the Mfr and model# of the router the Orbi RBR is connected too?
Is the Orbi system operating in Router or AP mode?
BarryMan
What Firmware version is currently loaded? on the Orbi RBR50 it is V2.5.1.16
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? the dsl modem is the Smart/RG VDSL2 Modem.
What is the Mfr and model# of the router the Orbi RBR is connected too? the router is the 844E GigaCenter
Is the Orbi system operating in Router or AP mode? Not sure where I can check this
thanks
- FURRYe38Jun 29, 2020Guru - Experienced User
So you have a router already at the GigaCenter which is also a modem. This is connected to a VDSL modem as well?
The orbi already is a router and having two routers on the same line will cause problems.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying option #3 with the Orbi RBR.
