Stcook
Apr 27, 2017Follower
New Orbi satellite RS50 stays solid white
Bought router and 2 satellites. Router and 1 satellite working fine. Second satellite powers up but ring stays solid white, no blinking and won't sync. Paper clip to reset button has no effect. Any solution?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Stcook
I would suggest contacting support if there is a hardware issue they will be able to rma you a new unit.
http://www.netgear.com/support/contact.aspx
DarrenM
