Emetw
Jan 30, 2017Aspirant
New Orbi setup, cannot get RDP to work
I just received my new Orbi setup and it is configured as follows: Router upstairs, one satellite downstairs. Workstation is plugged into satellite downstairs I use RDP on my Windows 10 lapt...
- Feb 02, 2017
Thanks everyoner, especially Mikey94025, you had the closest answer. My network connection on my workstation was good (set to public), but for some reason my homegroup had to be validated again. I did this by going to Control Panel>Network and Sharing Center>Homegroup and then rejoining there (Windows 8.1). All works now, both via LAN IP and external IP.
Thank you!
st_shaw
Jan 30, 2017Master
If you cannot get RDP to work on your LAN by accessing the workstation's local IP, then the problem likely with the workstation or the client, not the Orbi. Get it working on the LAN first, then try port forwarding.
Check Windows Firewall on the workstation. Turn the firewall OFF and see if RDP works. Did you change the subnet you are using on your LAN when you switched to Orbi? If so, maybe the firewall was setup to allow the old subnet.
Mikey94025
Jan 30, 2017Hero
You created a new Wireless network when you setup your Orbi. It's likely blocking RDP. If you right-click the wireless taskbar icon and Open Network and Sharing Center, does it say "private network" or "public network"? I believe that public defaults to blocking RDP. You can switch it by left-clicking the wireless taskbar icon, select your wireles network, click the Properties link of that network, then turn on Make this PC Discoverable.
- EmetwFeb 02, 2017Aspirant
Thank you!
