tweill
Oct 04, 2019Aspirant
New Orbi Voice R40 not connecting with existing Orbi R50 network
I am having trouble adding the Orbi Voice to my existing Orbi system. The Orbi app updated my firm ware prior to adding the Orbi Voice. I go to add Satellite and it keeps telling me it can't be fou...
Oct 04, 2019Guru - Experienced User
https://www.netgear.com/support/product/RBS40V.aspx
here's the support page with firmwares and manuals
tweill
For a non-tech person, how do I find the firmware for the R40 since I can't get it to connect?
- plemansOct 04, 2019Guru - Experienced User
I think someone had found that if you hardwire into the orbi satellites and they aren't connected to anything that their default ip address is 192.168.1.250. You can try that route.
Have you tried to sync using the app or even just using the hardwired sync buttons on the orbi units?
