mgdurand1
Nov 19, 2017Luminary
New Orbis - MESH or Hub and Spoke?
I have the oroginal Orbi and could not be happier. I read that it is not a true MESH system as each satellite communicates directly with the router through the dedicated back channels. I see a new Orbi system out (the AC2200 set, I think). Claims up to 8000 sq feet coverage. A diagram suggests that it is a true MESH system as it shows a satellite communicating with another satellite. Anyone know if that is the case or are all Orbi systems still Hub and Spoke? Thanks.
mgdurand1 wrote:...A diagram suggests that it is a true MESH system as it shows a satellite communicating with another satellite...
The diagram is correct and the result of one of the latest firmware releases for the systems.
See https://kb.netgear.com/000048467/RBR50-RBS50-Firmware-Version-2-0-0-74 and
https://kb.netgear.com/000048463/RBR40-RBS40-Firmware-Version-2-0-0-56
- tagteamVirtuoso
- mgdurand1Luminary
Many thanks for that quick response! Just the answer I needed. Again, thank you.
