Joe1212
Jul 20, 2019Aspirant
new phone connection
I got a new phone and it would not connect so I changed my password to make sure it was correct and I still can not connect any sugestions?
CrimpOn
Jul 20, 2019Guru - Experienced User
How was the password changed?
Do other devices connect and operate correctly?
Joe1212
Jul 21, 2019Aspirant
Connected via the app all other devices connected
- CrimpOnJul 21, 2019Guru - Experienced User
What WiFi channels is the Orbi using?
- Joe1212Jul 21, 2019Aspirant
I don't know
This is amazing. I opened the Orbi app and cannot seem to find any information about the WiFi channels. On the web interface, it appears on the Home screen.
The reason for the question is a process of elimination. i.e. (1) every other device connects to the Orbi and works normally, (2) one device does not connect, thus (3) something about this device does not match the Orbi. There have been situations in the past where Orbi's were located in countries that allow more WiFi channels than the US (specifically 12, 13, 14) and the user has a device that is set to "US only".
That should not affect a 5G connection, but I wanted to rule it out from the start.So, what else can be different about the LG phone?
