RickDangerous
Feb 01, 2018Star
New problem: “Connection is not private”
New issue has arisen with the latest firmware. I can’t connect via WiFi to any websites (including orbilogin) as it either brings up a message saying the “Connection is not private”, or a dialog box a...
RickDangerous
Feb 01, 2018Star
Thanks for the suggestion, but no, I haven’t changed any of the settings.
budy
Feb 02, 2018Luminary
Have you checked the AP's BSSID, when you encounter this issue - is this really your AP?
- RickDangerousFeb 02, 2018StarThanks for this suggestion but I think it really is.
I’m using the Orbi in router mode and I wonder if that could be contributing in some way?- budyFeb 02, 2018Luminary
Then examine the SSL certificate and see who did sign it. It your Orbi signed it, when it really would be performing some traffic inspection.
- kfackler819Feb 07, 2018AspirantWas this resolved for you? Having the same issue.
