Jul 25, 2021Guru - Experienced User
New RBK20/40 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled. Security Fixes: Fixes security vulnerability issues. For more information about se...
Aug 02, 2021Guru - Experienced User
đ
jweise
Aug 03, 2021Apprentice
This post caused me to check if my system had been auto updated to 2.7.3.22. I was amazed to find that it had! This is the first auto update that I can recall in the last 3 years. Do not know what casused them to push it at this time. Fortunately my system appears to be working fine.
- FURRYe38Aug 03, 2021Guru - Experienced User
You might power OFF the RBS and RBR and ISP modem for 30 seconds and power back ON in reverse order then do a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
jweise wrote:This post caused me to check if my system had been auto updated to 2.7.3.22. I was amazed to find that it had! This is the first auto update that I can recall in the last 3 years. Do not know what casused them to push it at this time. Fortunately my system appears to be working fine.
