Jul 25, 2021Guru - Experienced User
New RBK20/40 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled. Security Fixes: Fixes security vulnerability issues. For more information about se...
Aug 02, 2021Guru - Experienced User
Ok, sounds like the RBR is hosed pretty good.
Please send a PM to Blanca_O and Christian_R and explain the situation to them and see what options maybe available to you.
spiderfiend wrote:I'm not getting anything from the serial console at all after setup and plugged in. Tried multiple reboots and console is blank.
This is really frustrating! I can't afford to buy a whole new router after less than a year and a half!
spiderfiend
Aug 03, 2021Aspirant
I haven't heard back from them yet. Is there someone else that I need to reach out to?
Thank you!
Thank you!
- FURRYe38Aug 04, 2021Guru - Experienced User
Keep trying...
Thank you!
