Jul 25, 2021Guru - Experienced User
New RBK20/40 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled. Security Fixes: Fixes security vulnerability issues. For more information about se...
dburg
Aug 17, 2021Aspirant
All devices were losing wireless Internet connection reporting issues with DNS names resolution.
I had no such issues after disabling Traffic Counter and NTP Daylight Update
- FURRYe38Aug 17, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- dburgAug 17, 2021Aspirant
The router was powered off, modem as well.
No configuration reset were undertaken since too many settings had to be reconfigured.
