Jul 25, 2021Guru - Experienced User
New RBK20/40 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled. Security Fixes: Fixes security vulnerability issues. For more information about se...
Aug 17, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
dburg wrote:
All devices were losing wireless Internet connection reporting issues with DNS names resolution.
I had no such issues after disabling Traffic Counter and NTP Daylight Update
dburg
Aug 17, 2021Aspirant
The router was powered off, modem as well.
No configuration reset were undertaken since too many settings had to be reconfigured.
