Jul 25, 2021Guru - Experienced User
New RBK20/40 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled. Security Fixes: Fixes security vulnerability issues. For more information about se...
Aug 17, 2021Guru - Experienced User
toto123
Jan 10, 2022Aspirant
is there a timeline on a new firmware verison?
- FURRYe38Jan 10, 2022Guru - Experienced User
Uknown. Are you having problems?
Please make a new post if your having problems and lets see if we can help out. If not, please contact NG support for help and information as well:
https://my.netgear.com/support/contact.aspx
- CrimpOnJan 10, 2022Guru - Experienced User
In over four years, I have never seen Netgear announce a date when firmware will be released. (for any product)
No router mfr announces when new FW is forth coming in all my experiences.
- tagteamMar 03, 2022Virtuoso
FURRYe38 wrote:No router mfr announces when new FW is forth coming in all my experiences.
Yeah, but it's been over 7 months since the last release. I'm not experiencing any issues but it's sort of hard to believe NG has not discovered any security vulnerabilities or otherwise fixed any outstanding issues.
