Jul 25, 2021Guru - Experienced User
New RBK20/40 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled. Security Fixes: Fixes security vulnerability issues. For more information about se...
Jan 10, 2022Guru - Experienced User
No router mfr announces when new FW is forth coming in all my experiences.
tagteam
Mar 03, 2022Virtuoso
FURRYe38 wrote:No router mfr announces when new FW is forth coming in all my experiences.
Yeah, but it's been over 7 months since the last release. I'm not experiencing any issues but it's sort of hard to believe NG has not discovered any security vulnerabilities or otherwise fixed any outstanding issues.
- FURRYe38Mar 05, 2022Guru - Experienced User
And doesn't mean that there not working on something. Also Orbi AC, being the more matured product line, may not require as frequent FW updates as new Orbi AX so NG maybe prioritizing FW updates across Orbi product lines.
"If it's working, Don't Fix it!!!." No offence.
- FURRYe38Apr 23, 2022Guru - Experienced User
