SLPaul
Apr 28, 2020Aspirant
New RBK23 System Installation
I currently have a Fios-GT1100 running my home wireless. I want to add the Orbi RBK23 system, but have it setup with the same SSID that my Fios has so that I don't have to change all of my devices. ...
Apr 29, 2020Guru - Experienced User
Yes and Yes.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
SLPaul
Apr 29, 2020Aspirant
Thanks.
In order to do this right, I did a factory reset on the Orbi Router and both satellites.
Now, however, from the app (or any device actually) I can no longer find the default Orbi SSID (Orbi64).
Any suggestions?
Thanks,
Scott
- FURRYe38Apr 29, 2020Guru - Experienced User
Can you use a wired PC and web browser to log into the RBRs web page at 192.168.1.1?
