SLPaul
Apr 28, 2020Aspirant
New RBK23 System Installation
I currently have a Fios-GT1100 running my home wireless. I want to add the Orbi RBK23 system, but have it setup with the same SSID that my Fios has so that I don't have to change all of my devices. ...
SLPaul
Apr 29, 2020Aspirant
Thanks.
In order to do this right, I did a factory reset on the Orbi Router and both satellites.
Now, however, from the app (or any device actually) I can no longer find the default Orbi SSID (Orbi64).
Any suggestions?
Thanks,
Scott
Apr 29, 2020Guru - Experienced User
Can you use a wired PC and web browser to log into the RBRs web page at 192.168.1.1?
