Jul 06, 2021Guru - Experienced User
New RBK50/53 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled Security Fixes: This firmware addresses security vulnerabilities. For more informatio...
- Sep 22, 2021
Update from me on this firmware. After using sometime I was getting rpoblems with wired devices. These devices did no longer get connection. Power cycle of the (non managed) switch resolved the issue. Howerv it returned then suddenly I noticed that my Andorid S10 phone (latest firmware) did no longer get good connection to the Wifi (no internet and no data).
Switching off router and satellites did only fix it for a few minutes and then issues start re-occuring. Other HW also wired connected did not get any internet anymore.
Full reset of the system (by using the reset button on the back) and then restore fixed everything anf the system is working again. It looks like it corrupted somewhere.
Another great experience of Orbi. I decided to purchase another system and will sell this. Too many issues
SkywalkerPD
Jul 07, 2021Apprentice
Satellite is NOT upgrading with this file..... (RBS50-V2.7.3.22.img)
Just tried two times and two times the result after patching en restarting is:
- Firmware Version: V2.7.2.104
The router itself went fine.
SkywalkerPD
After re-downloading and updating the Satellite for 4 times. It now shows the (right) new firmwarre version.
SkywalkerPD wrote:Satellite is NOT upgrading with this file..... (RBS50-V2.7.3.22.img)
- FURRYe38Jul 07, 2021Guru - Experienced User
What browser were you using?
SkywalkerPD wrote:After re-downloading and updating the Satellite for 4 times. It now shows the (right) new firmwarre version.
- SkywalkerPDJul 07, 2021Apprentice
FURRYe38 wrote:What browser were you using?
Upgrade was done with the Edge browser....
Ok. Interestning it took a few tries. Possible the browser cache didn't update correctly. Glad it took for you.
