Jul 06, 2021Guru - Experienced User
New RBK50/53 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled Security Fixes: This firmware addresses security vulnerabilities. For more informatio...
- Sep 22, 2021
Update from me on this firmware. After using sometime I was getting rpoblems with wired devices. These devices did no longer get connection. Power cycle of the (non managed) switch resolved the issue. Howerv it returned then suddenly I noticed that my Andorid S10 phone (latest firmware) did no longer get good connection to the Wifi (no internet and no data).
Switching off router and satellites did only fix it for a few minutes and then issues start re-occuring. Other HW also wired connected did not get any internet anymore.
Full reset of the system (by using the reset button on the back) and then restore fixed everything anf the system is working again. It looks like it corrupted somewhere.
Another great experience of Orbi. I decided to purchase another system and will sell this. Too many issues
nicholb
Jul 25, 2021Luminary
New system arrived early. Boy is it noticably faster. I can only conclude something in the Orbi was causing a slowdown as my internet speeds are 400/20 which should have been well with in the Orbi capability. I noticed the speed checks on the Orbi were a bit slow and I had done a full reset and configure by hand back when 104 came out with no change.
Ha_Ku_Na
Jul 26, 2021Luminary
nicholb wrote:New system arrived early. Boy is it noticably faster. I can only conclude something in the Orbi was causing a slowdown as my internet speeds are 400/20 which should have been well with in the Orbi capability. I noticed the speed checks on the Orbi were a bit slow and I had done a full reset and configure by hand back when 104 came out with no change.
Could you send me a PM with the information about your new mesh. I'm also on the way away from netgear products.
- FURRYe38Jul 26, 2021Guru - Experienced User
Some RBR50 v22 Speed results:
Iphone 12 Max iOS 14.6:
ASUS GT-AX11000 wireless bridge mode:
Wired 1000Mbps Windows 10x64 connected to RBR50:
- nicholbJul 27, 2021Luminary
Much better speed than I was able to get. For over a year I had not been able to get over 200 down wireless on a 400 service. Wired was fine from the router and got near 400. It did not matter if I was connected to the router or satellite. I even did the full factory reset and manual setup a few months ago to see if that would help.
- FURRYe38Jul 27, 2021Guru - Experienced User
WIred should see near 400Mpbs if thats what you get from the ISP. Wireless kind of depends on device and there max supported speeds and mimo antenna support. 2x2 are usually limited to 300-500 range. 4x4 antenna supports much higher speeds.
Same testing device on the new mesh sytem gets 350-450 wireless. Only difference is changing out the Orbi.
What wireless devices are you testing with?
Hopefully keeps working well for you. Keep an eye on it.
Similar results on 3 testing devices. Samsung S21 Ultra, Samsung Tab S7+, and an Alienware Win 10 laptop.
OK, thanks.
