Jul 06, 2021Guru - Experienced User
New RBK50/53 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled Security Fixes: This firmware addresses security vulnerabilities. For more informatio...
- Sep 23, 2021
Update from me on this firmware. After using sometime I was getting rpoblems with wired devices. These devices did no longer get connection. Power cycle of the (non managed) switch resolved the issue. Howerv it returned then suddenly I noticed that my Andorid S10 phone (latest firmware) did no longer get good connection to the Wifi (no internet and no data).
Switching off router and satellites did only fix it for a few minutes and then issues start re-occuring. Other HW also wired connected did not get any internet anymore.
Full reset of the system (by using the reset button on the back) and then restore fixed everything anf the system is working again. It looks like it corrupted somewhere.
Another great experience of Orbi. I decided to purchase another system and will sell this. Too many issues
vondie
Aug 04, 2021Aspirant
Ok. I've not try that yet. thank you
Gebla
Aug 05, 2021Apprentice
This release is broken as well. Wired devices connected to a hub have drop outd and loose internet connection for short time
Yes i tried factory reset.
When will Netgear finally release a firmware that is working? This is becoming a big joke.
- FURRYe38Aug 05, 2021Guru - Experienced User
What is this 'hub' your revering too?
Is this a switch? Brand and Mfr?
What wired devices do you have connected?
When will Netgear finally release a firmware that is working? This is becoming a big joke.- GeblaAug 05, 2021ApprenticeApologies with hub i mean satellite
- FURRYe38Aug 06, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
