Jul 06, 2021Guru - Experienced User
New RBK50/53 Series Firmware Version 2.7.3.22
Bug Fixes: Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled Security Fixes: This firmware addresses security vulnerabilities. For more informatio...
- Sep 22, 2021
Update from me on this firmware. After using sometime I was getting rpoblems with wired devices. These devices did no longer get connection. Power cycle of the (non managed) switch resolved the issue. Howerv it returned then suddenly I noticed that my Andorid S10 phone (latest firmware) did no longer get good connection to the Wifi (no internet and no data).
Switching off router and satellites did only fix it for a few minutes and then issues start re-occuring. Other HW also wired connected did not get any internet anymore.
Full reset of the system (by using the reset button on the back) and then restore fixed everything anf the system is working again. It looks like it corrupted somewhere.
Another great experience of Orbi. I decided to purchase another system and will sell this. Too many issues
Aug 22, 2021Guru - Experienced User
YOu could use your ISP modem/router to block Orbi FW updates.
Retired_Member wrote:
Just to share my experience of this firmware update. I did the update but then a few days later noted that I was getting semi regular freezes while playing online games. During work hours, VPN connections would drop every 15 to 30 minutes. This was happening on both wireless and wired connections.
I'd completely forgotten about the firmware update. Tried hard reboots, factory resets, nothing seemed to solve it and plugging in my old ISP router gave a very stable less laggy connection.
I then remembered the firmware update and timing seemed not to be a co-incidence. Reinstalled the previous firmware, router restarted. Problem gone and stable connections resumed. I'll avoid this update and if it updates automatically I'll just downgrade again.
Gebla
Sep 22, 2021Apprentice
- FURRYe38Sep 23, 2021Guru - Experienced User
Thanks for letting us know a reset worked. Resets can and usually fix odd issues seen after FW udpates.
Good Luck.
- FURRYe38Apr 11, 2022Guru - Experienced User
New FW released:
