QuakerWildcat
Apr 05, 2020Aspirant
New RBR20 - Affecting Ethernet in house?
Is there some reason that my new Orbi would interfere with my wired ethernet? Background: I had decent connectivity in my house, with ethernet throughout, but with the demarc point (and FiOS rout...
CrimpOn
Apr 05, 2020Guru - Experienced User
The Orbi default mode is as a "router", which means it will respond to DHCP requests. When devices broadcast a DHCP request, any DHCP server on the network can respond and the device talks to the first one that does. I would switch the Orbi to Access Point (AP) mode.
- QuakerWildcatApr 05, 2020Aspirant
CrimpOn, thanks for the quick reply. This makes a sense, BUT:
- About an hour after setting up the Orbi RBR20, all of the devices in the house that were hard-wired via ethernet to the FiOS router started working again, so I'm wondering if I should just leave well-enough alone.
- I had simply followed the setup instructions and used the Orbi app, and I don't see any settings in the app for router vs. access point. Where/how would I do that?
- What other nifty features won't I find on the app?
Thanks. This bit is a pain but overall I AM seeing improved WiFi performance and coverage.
- FURRYe38Apr 05, 2020Guru - Experienced User
You'll find more user features if you use a web browser and log in to the RBRs web page.
Glad is working now.
- CrimpOnApr 05, 2020Guru - Experienced User
QuakerWildcat wrote:CrimpOn, thanks for the quick reply. This makes a sense, BUT:
As FURRYe38 pointed out, most of the "interesting" Orbi settings can be accessed only from the web interface. i.e. a web browser opening http://orbilogin.net.
One thing to be aware of is complications of having two routers, which is often called a "Double-NAT". https://kb.netgear.com/30186/What-is-Double-NAT You can get really lucky and never have a problem, but there are myriad situations which "just don't work", such as trying to open ports for servers to be reached from the internet, specific internet gaming issues, trying to use OpenVPN to access the Orbi when away from home, using printers, etc..
