QuakerWildcat
Apr 05, 2020Aspirant
New RBR20 - Affecting Ethernet in house?
Is there some reason that my new Orbi would interfere with my wired ethernet? Background: I had decent connectivity in my house, with ethernet throughout, but with the demarc point (and FiOS rout...
Apr 05, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Is your FIOS router bridged or in router mode?
What is the Mfr and model# of the ethernet switch in the configuration if one is being used?
Is Daisy Chain enabled? If so, disable it on the RBR and check.
Under Advanced Tab/Advanced Settings/Wireless Settings
QuakerWildcat wrote:Is there some reason that my new Orbi would interfere with my wired ethernet?
Background: I had decent connectivity in my house, with ethernet throughout, but with the demarc point (and FiOS router) in one corner of the house, WiFi was spotty on the far end. I had a TP-LINK access point on the that far end of the house, but that was dropping a lot, and so I sprung for the Orbi Mesh Router.
This morning I set up the Orbi in the center of the house, and the satellite directly above it on the 2nd floor. For everybody's convenience, I gave it the same SSID as the FiOS router, and then turned off WiFi on the FiOS router. WiFi now seems to be working great at all corners.
What's weird: the PCs connected via hard wired ethernet connections throughout the house all say "Unidentified Network: No Internet".
What's weirder: The Orbi itself is connected via ethernet through a switch to the FiOS router, so I know ethernet is working for the Orbi.
I'm not a networking expert. What am I missing?
