QuakerWildcat
Apr 05, 2020Aspirant
New RBR20 - Affecting Ethernet in house?
Is there some reason that my new Orbi would interfere with my wired ethernet? Background: I had decent connectivity in my house, with ethernet throughout, but with the demarc point (and FiOS rout...
QuakerWildcat
CrimpOn, thanks for the quick reply. This makes a sense, BUT:
- About an hour after setting up the Orbi RBR20, all of the devices in the house that were hard-wired via ethernet to the FiOS router started working again, so I'm wondering if I should just leave well-enough alone.
- I had simply followed the setup instructions and used the Orbi app, and I don't see any settings in the app for router vs. access point. Where/how would I do that?
- What other nifty features won't I find on the app?
Thanks. This bit is a pain but overall I AM seeing improved WiFi performance and coverage.
Apr 05, 2020Guru - Experienced User
You'll find more user features if you use a web browser and log in to the RBRs web page.
Glad is working now.
