JDSiph
Sep 04, 2020Tutor
new RBR50 (& RBS50) with firmware 1.4.0.18
Hello. Just purchased a new Orbi AC3000 (RBR50 & RBS50). It is restarting itself every couple days (seems random and results in ~ 5 min network/WiFi outage). I was checking the firmware to see if ...
- Sep 07, 2020
Thanks all. I followed FURRYe38 advice and did manul updates as followed.
Started at 1.4.0.18 (what it was shipped with)
Manual update of Satellite and then Router in this order.
- 2.0.0.74 (Satellite)
- 2.0.0.74 (Router)
- 2.2.1.212 (Satellite)
- 2.2.1.212 (Router)
- 2.5.1.16 (Satellite)
- 2.5.1.16 (Router)
Seemed to work fine. Now running "current" firmware on both.
Thanks again....
Mstrbig
Sep 04, 2020Master
JDSiph wrote:Hello. Just purchased a new Orbi AC3000 (RBR50 & RBS50). It is restarting itself every couple days (seems random and results in ~ 5 min network/WiFi outage). I was checking the firmware to see if it is "current" and it says it's on V 1.4.0.18 and it also says "No New Firmware Versions Available" in the status field on through the web admin.
I see that this version was released in 2016 (it's now 4 years later) and the Netgear support website says the latest firmware is V 2.5.1.16. How am I this far out of date and why isn't some sort of a firmware update appear me obvious? Did I buy an older "new" unit? Can I update the firmware from 1.4.0.18 to 2.5.1.16? Seems crazy to drop $300 on a new system that appears to be stuck 4 years in the past. Who knows if this is part of my self-reboot problem.
Thanks for any advice.
I would go nback to the store you purchased it fr4om and ask the question about the unit.
You can get the official release firmware 2.5.1.16 from here and manually update:
https://www.netgear.com/support/download/
Just put in your model orbi and it will display the files for download for your router and satellite. Update the satellite first.
