JDSiph
Sep 04, 2020Tutor
new RBR50 (& RBS50) with firmware 1.4.0.18
Hello. Just purchased a new Orbi AC3000 (RBR50 & RBS50). It is restarting itself every couple days (seems random and results in ~ 5 min network/WiFi outage). I was checking the firmware to see if ...
- Sep 07, 2020
Thanks all. I followed FURRYe38 advice and did manul updates as followed.
Started at 1.4.0.18 (what it was shipped with)
Manual update of Satellite and then Router in this order.
- 2.0.0.74 (Satellite)
- 2.0.0.74 (Router)
- 2.2.1.212 (Satellite)
- 2.2.1.212 (Router)
- 2.5.1.16 (Satellite)
- 2.5.1.16 (Router)
Seemed to work fine. Now running "current" firmware on both.
Thanks again....
mrfranc
Sep 04, 2020Apprentice
Regarding the firmware:
I would try upgrading to V2.2.1.212, then to v2.3.0.32 and finally to V2.5.1.16.
https://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212
https://kb.netgear.com/000060603/RBR50-RBS50-Firmware-Version-2-3-0-32
https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16
Sep 04, 2020Guru - Experienced User
If v212 can be applied then then can go directly to v16. No v32 needed.
However I think they will need v74 first...
- mrfrancSep 04, 2020Apprentice
Just playing it safe. Since NG does not have a define upgrade path like others.
- FURRYe38Sep 04, 2020Guru - Experienced User
Understand. I Think safe would be v74 first, if that completes, then v212 then v16. I did experience this same path a few years ago with my friends Orbi, was at v1 and just happened to find v74. It updated then I was able to go the latest and greatest, at the time. :smileywink:
- JDSiphSep 07, 2020Tutor
- 2.0.0.74 (Router)
- 2.5.1.16 (Router)
Thanks again....
