nicoleto35
Apr 30, 2019Follower
New satelite for RBK 50
Hi,
i need to improve my Wifi, i have already a ORBI RBK50 and i want to know what kind of satellite i can install ?
thanks for any help
Nicolas
May 01, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Can install most any RBS, RBW(Wallplug) or RBSY(Outdoor) satellite. I recommend keeping with the same RBS50 series satellites to maintain same connetion rates and speeds as other model RBS connetion rates differ and are a bit slower than the 50 series.
