dcurnow
Sep 11, 2020Follower
New satellite - RBS50
Hi I'm after another RBS50 satelite but they dont seem to be available anymore? Do the RBS20/40 work with the RBR50 system? Or any others? Or is it just the newer RBS50Y now (much more expensive)? ...
Sep 11, 2020Guru - Experienced User
The RBS20, rbw30, rbs40, rbs40v, rbs50, rbs50y are all compatible with your system. The only different is that only the 50 series of devices have the 1733mbps backhaul. the others use a 866mbps backhaul.
but they do work.
