Clausi
Jun 14, 2022Follower
New satellite for RBK 50
I have a RBR50 + RBS50 (3 yrs old) and want to add another satellite. RBS50 is not available anymore. Which type do you recommend? Thx for your replies Clausi
- Jun 14, 2022
Clausi wrote:
I have a RBR50 + RBS50 (3 yrs old) and want to add another satellite. RBS50 is not available anymore. Which type do you recommend?Any of the original Orbi 'ac' models will connect to the RBR50, including
RBS50, RB40, RBS20, RBS30W, RBS40V, RBS50Y
Although not readily available through retail outlets, the RBS50 is available on eBay. I purchased an RBR50 router on eBay to use as a spare.
Jun 14, 2022Guru - Experienced User
Try a RBS40v.
Also EX7500, 7700 or 8000 would work too.
