Phandam
Mar 28, 2017Apprentice
New systems interchangable?
Hello Are the new Orbi systems (looks like there are 2) interchangable, so I could use the plug adaptor with my original Orbi router? Also, any updates when the satellites will be available i...
- Mar 28, 2017
I found the answer in a Verge article:
Netgear’s original Orbi will stay on sale, and all three of its Orbi units will be able to be used interchangeably within one system. That’ll allow homeowners to mix and match to figure out what works best for them — it’ll also allow for less expensive systems than what you originally had to pay for Orbi.
Phandam
Thanks both for your input. I will probably go for the original satelllite to keep the highest possible performance and stability, if it every becomes availabel in the EU.
