GregCook
Apr 26, 2020Guide
New to Orbi - RBK50 / RBR50 V2 - rebooting often
Hi All new to orbi and coming from a d7000 Have the RBK50 kit. Live in New Zealand. Have set up the router, did a factory restore and installed 2.5.1.8 firmware. Ran the unit withou...
GregCook
Apr 27, 2020Guide
Hi
Yeah cant say i agree sorry, there is no real need to upgrade, i already tried .16 and had issues.. what my system thinks it wants and what works are two different things :)
Retired_Member
Apr 27, 2020
GregCook wrote:Hi
I think you're missing my point.................which is stop doing manual updates. The only reason I mentioned the upgrade at this point is that I've read of some success with the other version. Your only other option (other than sit there and suffer) would be to revert back to a previous stable version.
Good luck
- GregCookApr 27, 2020GuideHeya
So I think you missed the part where I said after reverting backwards it showed on the device I needed to upgrade ( from .30 to .16) and so I did that as per the device firmware update method. Eg not manually . That still didn’t work so I rolled back. I’m not just upgrading manually. I’ve used both approaches. Right now I’m 8 hours without a reboot. On .30. Biggest change was setting 2.4ghz to fixed channel 6 rather than auto as I read that might help. . Why I don’t know- Retired_MemberApr 27, 2020
what I'm saying IF you reverted....did it ever stablize?
GregCook wrote:
Heya
Pay no attention to what the device says about upgrading. IF your system needs an update NG will push it to you automatically. No acttion required on your part.
this is where I think you keep making your mistake..." after reverting backwards it showed on the device I needed to upgrade ( from .30 to .16) and so I did that as per the device firmware update method. Eg not manually "IF you had to click something to perform an update that IS manual.
