GregCook
Apr 26, 2020Guide
New to Orbi - RBK50 / RBR50 V2 - rebooting often
Hi All new to orbi and coming from a d7000 Have the RBK50 kit. Live in New Zealand. Have set up the router, did a factory restore and installed 2.5.1.8 firmware. Ran the unit withou...
GregCook
Apr 27, 2020Guide
Heya
So I think you missed the part where I said after reverting backwards it showed on the device I needed to upgrade ( from .30 to .16) and so I did that as per the device firmware update method. Eg not manually . That still didn’t work so I rolled back. I’m not just upgrading manually. I’ve used both approaches. Right now I’m 8 hours without a reboot. On .30. Biggest change was setting 2.4ghz to fixed channel 6 rather than auto as I read that might help. . Why I don’t know
Retired_Member
Apr 27, 2020what I'm saying IF you reverted....did it ever stablize?
GregCook wrote:
Heya
Pay no attention to what the device says about upgrading. IF your system needs an update NG will push it to you automatically. No acttion required on your part.
this is where I think you keep making your mistake..." after reverting backwards it showed on the device I needed to upgrade ( from .30 to .16) and so I did that as per the device firmware update method. Eg not manually "
IF you had to click something to perform an update that IS manual.
