GregCook
Apr 26, 2020Guide
New to Orbi - RBK50 / RBR50 V2 - rebooting often
Hi All new to orbi and coming from a d7000 Have the RBK50 kit. Live in New Zealand. Have set up the router, did a factory restore and installed 2.5.1.8 firmware. Ran the unit withou...
GregCook
Apr 27, 2020Guide
Ok so a further update.
Today i rang the RBR50 isolated from everything.. i had one laptop connected via wifi to allow me to see the logs etc..
No internet connection or wan or anything... just a RBR50 with power.
Unit ran for about 3 - 4 hours. didnt reboot. Then i noticed the network was gone, I waited for the device to reboot as it normally does, however this time i noticed nothing coming back up. Kinda strange.. checked the router, the power switch was on, but no green power LED. no unit connection status LED either WTF. So i turned the unit off and back on and it worked again... its now sitting there with a magenta flashing light as there is no internet connection and running for 1 hour.
So question . do the devices power off, shut down etc, kinda strange it would do that..
Feels like this is a dud and i will need to get a replacement.. Thats going to be challenging in itself.
Cheers
GregCook
Apr 28, 2020Guide
Next update. device crashed again, same scenario, no connections, no internet, just sitting there with a purple light, and decided to had enough. so im somewhat convinced the device is a dud... time to figure out how to exchange it.
- LiquidcoreApr 28, 2020StarHey Greg, certainly sounds like a dud! I have the RBK50 on 2degrees and it operates fine (apart from not being able to handle gigabit PPPoE but that's another story!)
Hopefully exchanging it will be a bit easier now that the alert level has dropped? - GregCookApr 28, 2020GuideNice to get a sanity check from another kiwi!! And good to know it can work. Are you not getting 900mbps . I’m only on a 100mbps plan and getting full speed on that.
Thank you. I’ll speak to PBTech. - FURRYe38Apr 28, 2020Guru - Experienced User
Return the system or ask NG for an RMA.
GregCook wrote:Next update. device crashed again, same scenario, no connections, no internet, just sitting there with a purple light, and decided to had enough. so im somewhat convinced the device is a dud... time to figure out how to exchange it.
- theoakApr 28, 2020Luminary
So, sadly, I am experiencing random reboots. I have tried 2.5.1.8, 2.5.1.16, and I have even downgraded to 2.3.5.30. Random reboots on all.
Support had me:
1. Change to channel 11 and 44.
2. Swap a power adapter between one of the satellites and the router.
3. Have the Orbi update me to what it wanted it to ... which was 2.5.1.16. Hence the update file came from where ever the Obri pulled it from, versus me manually downloading and applying the update. So the system ended up updating from 2.3.5.30 to 2.5.1.16.
Lets see what happens ...
Maybe the above ideas may help you.
- GregCookApr 28, 2020GuideUnfortunately I’ve done all the above. Including letting it do it’s updates. So far that hasn’t resolved my issues . :(. Best of luck though
Does this happen wtih Voxels FW as well?
Happens with the RBR online connected with RBS OFF?
Happens with the RBR disconnected from the ISP modem/ONT?
theoak wrote:So, sadly, I am experiencing random reboots. I have tried 2.5.1.8, 2.5.1.16, and I have even downgraded to 2.3.5.30. Random reboots on all.
Support had me:
Device rebooted again. Got approved for an RMA; unfortunately, none are in stock :( As soon as one is available, it will be sent. I will have to limp along until then.
- FURRYe38Apr 29, 2020Guru - Experienced User
Curious, did you try Voxels FW?
Do you have a prior your you could use has your host router, then configure the Orbi for AP mode?
theoak wrote:Device rebooted again. Got approved for an RMA; unfortunately, none are in stock :( As soon as one is available, it will be sent. I will have to limp along until then.
- theoakApr 29, 2020Luminary
FURRYe38 wrote:Curious, did you try Voxels FW?
I am still in my 90 days of full support, so I did not want to venture too far off the approved path.
My final last ditch effort (I have said that before too) in hopes to bring increased stability until the new one arrives ... I "Erase"d (Revert to factory default settings) via the GUI ... followed by a pin reset on the router ... followed by configuration.
Way back in my R7000 days, and earlier for that matter, that was the common recommendation when resetting the device. Folks said back then that both were not needed as they should be the same, but others swore by it.
Long story short ... thus far I am pushing 12 hours of up time .. which is one of my longer runs. We'll see what happens once the kids get on for school.
Ok, was wondering.
Yes, been contention with factory resets. I have for years now used resets with in my process troubleshooting or FW updates which I have never seen odd issues like random reboots or other oddities. Factory reset has been and always will be a valid troubleshooting step that for most users should be a last resort effort to see if it changes things. Most cases it does and does solve problems, thus is why its a needed and valid step.
Hoping that this will be the case for you as well. I was thinking regardless of of your warranty, while you are waiting on an RMA since they are out of stock, you could try Voxels FW to see if it brings stability as another last resort kind of thing. You can always revert your system back to stock FW before sending this system back to NG.
Hoping the reset will bring better operation. Be sure to make a backup configuration to file for safe keeping.
Keep us posted.
- Retired_MemberApr 29, 2020
Factory reset has been and always will be a valid troubleshooting step that for most users should be a last resort effort to see if it changes things. Most cases it does and does solve problems, thus is why its a needed and valid step.Mostly true in the case of manual updates. Auto-push has a lower rate of the need to trouble shoot. If it ain't broke...don't fix it:smileyhappy:
- theoakMay 10, 2020Luminary
Got my replacement:
- They only replaced the router versus the whole kit.
- New router booted up to 2.3.5.30 firmware.
- The serial number was actually "lower" than my now old kit was. Not sure if that means anything.
- Yes, I updated to 2.5.1.16 to match my satellites. Yes a manual update. The update page did say there was NO update available while on 2.3.5.30.
- I configured the new router from scratch. Considering I use Orbi in Access Point mode, it is not that bad.
- I did "erase" and pin reset the new router before configuration.
- I "removed" my satelltes from the original router and "erased" it to factory.
- I did have to sync my satellites to my new router.
Results:
- 1.5 days up time. So far so good! So far its a keeper.
I did have a work video chat meeting. I had one individual comment how "clear" my video was versus others and asked what settings I use. I said, no special setting - just my good looks - is why it is so clear. Everyone on the call laughed - not sure why :smileywink:
With a little luck it will keep on going.
- FURRYe38May 11, 2020Guru - Experienced User
Glad the new replacement is working out well. Let us know how it goes.
You looks may have broke the prior system. Hehe. Just kidding. :smileywink:
theoak wrote:Got my replacement:
Results:
- theoakMay 11, 2020Luminary
Ha! Yes, I probably "broke" my last router :smileyvery-happy:
Considering my router and satellites have different serial numbers, they are not naturally paired if I reset my router. If I restore my router from a backup, does that restore include satellite connectivity; or, will I have to re-sync the satellites again?
(Uptime: 2 days 17 hours ...)
- tomschmidtMay 11, 2020Virtuoso
My original RBR50 was also replaced with an RMA, and any factory resets that I have performed did not affect the RBS50 satellites from working again with the RBR50. I only had to resync the satellites once months ago when I replaced original router so that they would bind to its RMA replacement.
tomschmidt wrote:My original RBR50 was also replaced with an RMA, and any factory resets that I have performed did not affect the RBS50 satellites from working again with the RBR50. I only had to resync the satellites once months ago when I replaced original router so that they would bind to its RMA replacement.
Ah ... perfect.
So it must do some sort of "perma"-setting once you sync a satellite that survives a reset. Thanks for the quick reply.
- Agent_X20May 12, 2020Aspirant
I'm another RBR50 user from NZ. I purchased the Orbi setup to replace a pair of Asus routers. My ASUS gear worked 'ok' but my devices would endlessly roam back and forth between the two nodes causing poor all round performance.
My Orbi experience has been fair to poor all told. I mean this morning my RBR50 and satellite simply rebooted for no reason. And the useless logs of course are cleared down so I cannot troubleshoot things. Initially when I bought the Orbi a few months back I got quite a number of reboots and disconnects. Things have settled down somewhat with a couple of firmware updates but it still happens from time to time, with no discernable pattern or cause. I'm also somewhat unimpressed with the range of the Orbi gear compared to my very run of the mill Asus routers.
My iPhone 6S phone is also constantly resynching - switching nodes and endlessly renegotiating its speed (something I can see on the App). As a result it chews through my phone's battery. Of course it did this with the Asus gear as well but it seems, if anything, even worse with the Orbi.
The big saving grace for the Obrbi is the strong backhaul radio that has allowed me to get 'good' connectivity into my office during lockdown (no cables).
About the only thing I've not yet done, and I've tried all the usual swttings tweaks, is the factory reset process. I will do it, but with my network setup, the initial Orbi setting things up process can be a pain in the arse with clashing IP numbers etc.
Would I buy Orbi again? No almost certainly not. And I did come into this with some awareness of the problems people experience but underestimated the angst it would cause. Anyway, I just thought I'd relate my experiences as another Kiwi with the same gear.
- theoakMay 12, 2020Luminary
Agent_X20 wrote:...
Is your Orbi in Router mode? Static IP your known devices ... say X.X.X.2 to X.X.X.100. They set your DHCP for X.X.X.101 to X.X.X.200. This should prevent your DHCP from giving out an IP address that is already statically assigned.
- GregCookMay 12, 2020Guide
Thanks for the feedback, ive put through a repair, have a new unit in my hands, sealed in box. will likely not be keeping it will rever to the spark smart mesh system i think.. less painful..:)
theoak wrote:Is your Orbi in Router mode? Static IP your known devices ... say X.X.X.2 to X.X.X.100. They set your DHCP for X.X.X.101 to X.X.X.200. This should prevent your DHCP from giving out an IP address that is already statically assigned.
Yeah it's in AP mode. And yes you're absolutely right - my (pihole) dhcp server settings should make things easier for a reset. Cheers.
- LiquidcoreMay 13, 2020StarThe Spark Smart Modem + Mesh sounds like quite a decent device judging by the feedback on Geekzone! Also looks like it can even handle gigabit PPPoE. Good luck :)
I nearly gave my RBR50 up for a RT2600ac + MR2200ac combo but have decided to keep it and use it in AP mode behind a more capable router.
