watsintx
Dec 12, 2019Aspirant
New windows laptop is able to connect to Orbi router, but not satellite. Other devices okay.
I've had RBR40 router and 2 satellites for some time with no major issues. I received a new Windows laptop and it has trouble connecting/staying connected to satellite. No issues connecting to router...
- Dec 12, 2019
What Firmware is currently loaded? V2.3.5.30
What is the Mfr and model# of the ISP modem the NG router is connected too?Connected to AT&T Uverse Arris 5268AC
What is the size of your home? Sq Ft? 4200 sf
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. 40-50 ftWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channels 1 & 48
Any Wifi Neighbors near by? If so, how many? Yes, neighbors on sides, around 125 ftTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings Beamforming, WWM, and MIMO enabled
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). I've had backhaul issues when disabling Daisy Chain. I'll troubleshoot one by one, beginning with disabling Armor and Circle.Has a factory reset and setup from scratch been performed since last FW update? Yes
Updated: Disabling Armor seems to have worked! This couldn't have been the issue originally; however, because it was not active when I first started experiencing the problem. But it's working now and I don't want to mess with it.
Thank you!
Dec 12, 2019Guru - Experienced User
- watsintxDec 12, 2019Aspirant
Thank you!
- FURRYe38Dec 12, 2019Guru - Experienced User
Glad you got it working. Armor seems to cause problems here and there for users. I'd not use it if your don't need it.
Be sure to make a back up configuration to file for safe keeping.
Enjoy. :smileywink:
