watsintx's avatar
watsintx
New windows laptop is able to connect to Orbi router, but not satellite. Other devices okay.
I've had RBR40 router and 2 satellites for some time with no major issues. I received a new Windows laptop and it has trouble connecting/staying connected to satellite. No issues connecting to router...
  • watsintx's avatar
    watsintx
    Dec 12, 2019
    What Firmware is currently loaded? V2.3.5.30
    Connected to AT&T Uverse Arris 5268AC
    What is the size of your home? Sq Ft? 4200 sf
    What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. 40-50 ft
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channels 1 & 48
    Any Wifi Neighbors near by? If so, how many? Yes, neighbors on sides, around 125 ft
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings Beamforming, WWM, and MIMO enabled
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). I've had backhaul issues when disabling Daisy Chain. I'll troubleshoot one by one, beginning with disabling Armor and Circle.
    Has a factory reset and setup from scratch been performed since last FW update? Yes
    Updated: Disabling Armor seems to have worked! This couldn't have been the issue originally; however, because it was not active when I first started experiencing the problem. But it's working now and I don't want to mess with it.
    Thank you!
