Brads515
Apr 15, 2017Guide
Next Orbi Firmware Update...anyone know when?
I am hoping that the next Orbi firmware update will solve some of the major wifi speed issues and erratic speed issues I get on my Orbi system. Anyone have any idea of when the next firmware upda...
Glenee
Apr 30, 2017Apprentice
I checked the website and they still show V1.8.06 as current. Please make sure you are on the right netgear Item for your firmware updates. I have got into the wrong firmware update for the piece of equipment that I have before and ther eis no harm done it just won't take it.
All the Best,
Glen
alfista2600
Apr 30, 2017Aspirant
Hi Glen,
Thanks for the reply. I was not clear. I see this new firmware in the admin console of the router. It picks up a new version for the basestation, but not the satellites. I'll try to attach an image here:
I do not see this version of firmware anywhere on the netgear site. I wonder if I somehow have a pre-release/beta/test basestation which might explain the performance issues I'm having.
- ElyApr 30, 2017Luminary
My satellite wasn't updating either, after I rebooted both the sat and the main unit then both were able to download and take the firmware upgrade.
- alfista2600Apr 30, 2017Aspirant
what version are you at now? I've rebooted all three, and only the basestation will show an available (but as-of-yet unpublished) version of the firmware.
Both my main unit and the satellite are on V1.9.1.12, are you using your Orbi in AP mode?
Thanks.
I am running in Router mode. My satellites never show the update. I guess I'll go reboot them all. I don't see a way to manually download this firmware version.
alfista2600 yeah this can be frustrating, I was in the same situation yesterday when my sat wasn't getting the update, hopefully they will put it up on the site tomorrow, usually they delay a few days before they list officially, then you'll be able to download and install it manually, but yeah try another reboot.
I got it going. No remote reboot capabilities on the satellites but I rebooted the basestation and did an update as soon as it came up. The satellites followed suit.
Glad you got it going, but yeah, when I said reboot all units I meant manually, there's no remote reboot for the sats yeah.
- GleneeMay 01, 2017Apprentice
:mansurprised:My Mistake. When I go to the website it does not show that firmware. You must be getting it on a auto update, or by checking for new software. Netgear has so many products and you can download any of the firmware.
All my Best,
Glen
- DarrenMMay 01, 2017Sr. NETGEAR Moderator
The latest firmware is now posted on the support site.
http://www.netgear.com/support/product/RBK50.aspx#RBR50 (Orbi Router) Firmware Version 1.9.1.12
DarrenM
