whoopa
May 04, 2020Follower
NG Orbi : Second satellites drops Wi-Fi speed
Hello, I have a 200/200 fiber line. My modem is connected with Orbi router and they are in the same place. From the Orbi router a UTP (cat6) to a switch (NETGEAR GS105 5-port) from the switch t...
May 04, 2020Guru - Experienced User
