sandman1862
Nov 17, 2019Aspirant
Nighthawk AC 5300 and Orbi AC3000
I am trying to boost the outdoor signal from my Nighthawk AC5300 to extend to a pier. I have a piece of equipment that sends data to a receiver inside the house currently. I want to palce the recei...
Nov 17, 2019Guru - Experienced User
You might also look into a outdoor Orbi RBSY unit to go along with the Orbi 50 series system.
sandman1862 wrote:I am trying to boost the outdoor signal from my Nighthawk AC5300 to extend to a pier. I have a piece of equipment that sends data to a receiver inside the house currently. I want to palce the receiver closer to the pier and use an access point to access it as it is ethernet connected. Would the Orbi AC3000 work in this instance to extend the range to the shed to decrease the signal distance that the sensors have to their receivers? I need the access point (which is wireless) to send the signal back to the house but the signal from the access point isn't strong enough the reach the house. I am hoping that placing the Orbi outside the building would help with the signal.
