bugwhisperer
May 02, 2020Aspirant
Nighthawk Ac1900 and Orbi
I have installed an Orbi router and satellite with a Nighthawk aC1900 cable modem router. I want to turn the radios off the Nighthawk to avoid interference with the Orbi but I cannot access the Night...
bugwhisperer
Thank you! I entered through the gateway and turned the Radio button off. The Gateway address on Orbi changed and I can no longer access the Nighthawk as a modem. How do I check to confirm the procedure worked?
CrimpOn
May 02, 2020Guru - Experienced User
Just turning the WiFi radio off should not change the Orbi gateway. Putting the Nighthawk into "bridge" or "passthrough" mode would.
Is the "new" gateway a "public" IP address? (i.e. is does not start with 192.168, 10.10, or 172.16)
- bugwhispererMay 02, 2020Aspirant
The new gateway is 73.xxx.xxx.x
All I did was turn the radio button to off. It went into a reboot and I stepped away. Here we are. Thanks for your help!
It is now the same IP address as the Orbi..... no more 192.xxxx
and my download speed went from 202 to 17. Upload about the same
- CrimpOnMay 02, 2020Guru - Experienced User
bugwhisperer wrote:It is now the same IP address as the Orbi..... no more 192.xxxx
The Internet address of the Orbi is no longer 73.....?
Can you please identify which of these is your Nighthawk cable modem router?
https://www.netgear.com/home/products/networking/cable-modem-routers/
