mcervinojr
Apr 02, 2017Aspirant
Nighthawk or Orbi
Hi all, Looking for advice on a Network setup for our new summer home. The house is 3 levels, approximately 1,200 SF each level. First floor has kitchen, living room, 3 bedrooms. Second floor...
mcervinojr
Any recommendations on routers/APs?
st_shaw
Apr 02, 2017Master
I think Orbi should work very well for you. You could start with the base unit on the middle floor and one satellite on the top floor. Then you could add a second satellite on the bottom floor, if you needed it. You can also move the satellites easily if you need to adjust coverage.
As far as AP recommendations, I also have a second site with Ubiquiti APs. These work very well and provide a lot of information and configurability. Unless you buy the new expensive HD models, the single client throughput is less than Orbi though.
I'm not sure I can recommend a router. The ones I have experience with are either expensive and/or difficult to configure.
