mcervinojr
Apr 02, 2017Aspirant
Nighthawk or Orbi
Hi all, Looking for advice on a Network setup for our new summer home. The house is 3 levels, approximately 1,200 SF each level. First floor has kitchen, living room, 3 bedrooms. Second floor...
mcervinojr
That is the case. There is only a single drop on first floor, 2 on second floor and 2 on third floor. One in the third floor will be for the exterior.
I was thinking of going with an Ubiquiti Ap on each floor but I've heard mixed reviews.
- peteytestingApr 02, 2017Hero
I was thinking of going with an Ubiquiti Ap on each floor but I've heard mixed reviews.if you go with dedicated ap's you would still need to get a switch per drop as well , unless you have ceiling drops i dont think the dedicated ap's are as good a solution
the r7000 in ap mode gives you 4 ethernet ports to use as well as wireless ac coverage
and ether way you would still need a main router and what ever it needs to connect to the internet
what internet type does the house have ?
