mcervinojr
Apr 02, 2017Aspirant
Nighthawk or Orbi
Hi all, Looking for advice on a Network setup for our new summer home. The house is 3 levels, approximately 1,200 SF each level. First floor has kitchen, living room, 3 bedrooms. Second floor...
mcervinojr
That is the case. There is only a single drop on first floor, 2 on second floor and 2 on third floor. One in the third floor will be for the exterior.
I was thinking of going with an Ubiquiti Ap on each floor but I've heard mixed reviews.
peteytesting
Apr 02, 2017Hero
if you go with dedicated ap's you would still need to get a switch per drop as well , unless you have ceiling drops i dont think the dedicated ap's are as good a solution
the r7000 in ap mode gives you 4 ethernet ports to use as well as wireless ac coverage
and ether way you would still need a main router and what ever it needs to connect to the internet
what internet type does the house have ?
